New Edge 1030 Plus Public Beta 6.28 Now Available
A new Beta software for the Edge 1030 Plus has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1030 Plus: https://www8.garmin.com/support/agree.jsp?id=15682
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 6.26 to 6.28:
  • Added support for Connect IQ System 5.
  • Improved map turn review zoom level when approaching roundabouts at slow speeds.
  • Fixed issue where very long course names resulted in routing calculation failure.
  • Fixed issue where activities could be hidden from history.
  • Fixed issue with Daily Suggested Workout time estimates.
Changes made from version 6.24 to 6.26:
  • Fixed software crashes caused by encrypted CIQ programs that are no longer valid.
  • Fixed a couple of device stability issues.
Changes made from version 6.22 to 6.24:
  • Fixed automatic maximum heart rate detection.
  • Added the ability to perform the FTP test with power data coming from a trainer.
Changes made from version 6.10 to 6.22:
  • Changed gear battery data field to display percentage remaining if available, which affects Shimano Di2 single-battery systems.
  • Updated sensor low battery prompts to differentiate between low and critical status.
  • Fixed issue where distance could stop accumulating.
  • Fixed issue where text message sender names would display incorrectly.
    I'm not sure if there is still an issue. Might also be depending on my actual training situation.
    I got either "rest day" or "93 minutes base training".
    Nothing else in the last week since I updated... Before it was more variable... Just a feeling.
  • Same for me. Looks like it's on purpose.
    I guess if you would use the sequential setting of the SRAM it might make sense to have a notification of the front derailleur
    This is 11-speed Red eTap - there's no such thing as sequential automatic shifting of the FD, so having it bleep every time the FD is shifted is just an annoyance.
  • There is a bug in the current ANT+ shifting audio warning. Garmin are working on a fix. It should work the same as the Shimano Di2 shifting warning.
    When enabled it should give an audio warning when you reach the upper and lower limits of the gear range. E.g. Inner front front with inner rear cassette position or outer front ring with outer rear cassette position.
  • After the update a strange drops in speed from garmin speed sensor. Happens randomly, but when I stop pedalling the showed speed drops, including sometimes going into auto-pause, if I start pedalling it goes to correct one. Doesn't happen if i disconnect the speed sensor and use only the unit.
  • Does anyone know the solution to get the right time to a recorded route?
  • Where is your speedsensor mounted? Front or rear?
  • when will we get a reliable firmware. cycling season is on, come on garmin.dropouts with hr sensor, sram red etap losses and so on. or is my edge broken?
