A new Beta software for the Edge 1030 Plus has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1030 Plus: https://www8.garmin.com/support/agree.jsp?id=15682
Notes:
- For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 6.00 to 6.10:
- Fixed issue introduced in a recent public beta where the ANT search channel could remain open for the whole ride causing potential connectivity issues and draining battery unnecessarily.
Changes made from version 5.63 to 6.00:
- Fixed Back to Start issue when selecting Most Direct Route
- Fixed issue where LiveTrack could not be started
- Added a routing avoidance setting for interstate highways that allow bicycles. Previously, a user could not create a cycling route on interstates, even if the interstate allowed cycling.
Changes made from version 5.20 to 5.63:
- Fixed device-to-device transfers
- Added new tone for radar that that plays when your radar transitions to the green threat level. Go to the radar settings in the sensors menu to enable this feature.
- Improved bike light network connection stability
- Improved course point display and added new types
- Improved Course 'Always Show' functionality
- Improved shifting sensor battery data fields
- Improved Physio True-up data recording
- Improved indoor trainer control
- Fixed issue causing unnecessary sensor software update prompts
- Fixed power calibration prompt when waking from sleep mode
- Fixed history line color
- Fixed issue with left/right power balance recording
- Fixed issue with GPS not turning off in indoor mode
- Fixed the power graph during workout steps with no power target
- Improved general device stability
