Does anyone know why my power zone 7 doesn't show correct data? my zone 7 is always empty. Is it because on my device it shows 150%-150% for my zone 7? Is there a way I manually can edit it? Without removing the other ones.
You can manually edit the zone(s) on the unit by touching the zone you want to change or you can just select the bottom right icon and it should reset all the zones to the default % values.
