If you want a larger and more visible position marker on the map, write a request here. Maybe someone from Garmin will read it.
Absolutely YES.
The position marker needs to become larger! And Garmin can do it. Within the high contrast map profile they proofe it.
Garmin please make it a selectable option, independent of the map profile…
Placing a request on the forum does very little since Garmin does not constantly monitor the forum. There's a customer request form on the Garmin site that would be a more direct way of getting their attention…
There's a customer request form on the Garmin site that would be a more direct way of getting their attention.
Yes! Share Ideas | Garmin
I would like to have as standard cursor the one used with the high contrast map theme
You can
1. See this discussion, especially the 2nd & 3rd pages, https://forums.garmin.com/sports-fitness/cycling/f/edge-1030-plus/279890/which-cursor-size-is-better
2. Download, unzip and place the Theme file in your Garmin\MAPTHEMES directory,
3. Select this Theme in Settings>[Your Activity Profile]>Navigation>MAP>MAPTheme>Select the Theme...
4. Modify as needed if you want another color, I have also been trying pink (#ffF50B94)
