Intensy minutes
I assume some of the 1030 plus users also use a Fenix 6 . I know that Garmin in their wisdom have skipped/forgot to give support for intensy minutes on the Edge serie. So how do you collect this ? Should’nt (in theory) be a problem as long as both devices (in theory) support true up. Yesterday i went for a ride, recorded with the Edge and had the Fenix on my wrist without start any activity. No problem with intensy minutes, they was counted for. When i was finished i synced the ride from Edge to GC , recovery time was 26 hour. After i turned it off and connected the fenix 6 and synced. It had registered a recovery time of 3 hours . I did assume that the recovery time from the registered exercise in Edge would show up in Fenix, but no, instead when i came home and synced t,he Edge once more i had 3 hour recovery on the Edge as well. Is this normal behaviour ?
