Hi, I recently purchased a 1030 plus, now I have a couple of questions. First of all, I want to know if there is a setting I can enable for when I push the lap button It automatically switches to my own lap screen that I've set up. I had this function on my wahoo element bolt and I couldn't find it anywhere on the Garmin.
Second, i have an issue with navigation I think? it shows two lines instead of 1 to navigate? Is this just the line from the virtual partner ? I've read that you can't disable this? The route itself is from komoot and I can't seem to find a setting there that you can set the pace at (people suggesting that you set it very fast or slow) But I'm not sure if this is the problem can anyone verify ?
Here are some screenshots: https://imgur.com/a/mfjXx1h as you can see next to the water there isn't a road anymore but the Garmin shows there is??? Is it the virtual partner? it's very confusing.
