It takes several minutes to reconnect to them all. I have Varia light/radar, Polar HRM, Garmin speed sensor and a PowerPod v4 power meter. It was also happening with v11 software update.
You might get a response if you post this question in the Edge 1030 section
https://forums.garmin.com/sports-fitness/cycling/f/edge-1030
This happens with the 1030+ as well. I get it regularly at least once if not twice per ride - it disconnects every single sensor for a couple of seconds.
Today twice.
Would you be okay with sharing a public link to one of these rides? I understand if not completely.
Blake, I have it uploaded here: https://connect.garmin.com/modern/activity/7149093717
Added also the fit file.
Do you need the any log file / error file also? please tell me which file and where to locate within the Edge 1030 plus.
To add a little more info, after a "automatic migration" Profiles, sensors, etc... as I was having some issues I finally did a Factory Reset for the Device (Edge 1030 plus) and delete everything in my mobile device (bluetooth connection, and device from Garmin Connect App in Android) and configure everything manually (profiles, screens, activities, etc...) but sensors on the Edge itself, that I accept the "migrate" from Garmin Connect once installing it again, after connect again to the Garmin Connect app in Android.
Can you change this to a public activity?
Thank you for that. What is the power source on this ride, and what information does it provide? As in just power, power+cadence, etc.
It looks like your heart rate has no dropouts, but there do appear to be a couple in the power and cadence sections. When this happens, what do you see on your Edge? Is it 0 values or "--"?
