Hi,
I'm using a GPX Track for navigation. During the navigation the garmin displays informations of possible streets. Is there an option to disable these informations?
I've used this info more than one time to take the wrong way... :-)
Thx
Rossi02
Disable "turn giuldance".
If you look carefully, there's a bit of a bulge at the left. That's what is causing the left turn notification. If the turns are close together, they get displayed as one drawn-out arrow. This depends on the zoom level. That is, you might see the separate turns if you zoomed the map more.
