Hi
when using climb pro, very often the "remaining ascend" freezes. This happens mostly (probably always) on imported gpx tracks.
If I stop/restart the navigation, maybe to a slightly different route, what happens is that the new route shows on the map, but the "climb pro" window retains the old route climbs (still frozen)
I have to switch off the device (and loose the activity)
Any suggestion?
I have version 4.10: I will update the device, but only if this is a known bug that has been fixed.
Thank you
EDIT: I'm attaching images showing the issue. It was a video but my language was not very polite so I'm attaching just two frames.
Here the display correctly says "26 km to destination" (I just loaded a new destination)
But here the climb pro is still stucked on the previous climb (and says "next climb 34 km", that is beyond the end of the current navigation, which is impossible).
