Does the data and profile transfer feature of the 1030 Plus work when migrating from an Edge 810?
Have you already setup you Edge 1030 Plus?
The option to use this feature, from what I have read, will only be offered the first time you setup the device after receiving it. If you skipped this step during that initial setup, you cannot go back and run it later. Also, if the information stored on Garmin Connect from your Edge 810 is not compatible with the Edge 1030 Plus, the option to transfer profile data will be automatically skipped.
