I;m using a Wahoo blue HR strap, the edge tells me it is connected, but the data is not shown on the edge. Anyone a solution?
Have you also paired your mobile phone with the Wahoo Blue belt and with an app? If so, disconnect the strap from the phone.
That was my first mistake, but when I changed that I still have no data on the edge
Did you remove the sensor from the Edge und then start a reconnection?
And you have created a data field with heart rate on the screen? The HR sensor symbol is not flashing but permanent?
Is the connection established via Bluetooth or ANT+?
(If BT then change it to ANT)
The hart rate is shown as a stable icon on the edge. When I check even the information of the hart rate device is shown. I can see what device is connected. But it is just not shown on the edge. And yes it is connected via Bluetooth
When you start an activity, you can see a screen with differant data, for example speed, cadence and more.
Is there a data field for HR too with two underlines?
