Is there trick of is it a Bug?
configuration:
Later in the activity profile without any Information !
There is someone who could help?
configuration:
Is this a CIQ data field or built in data field supplied by Garmin?
It is Built in from Garmin, in German Menu "Grafisch"- "Herzfrequentkurve" in English maby graph(s)- HR_Graph
<tag>TXT_Cnfg_List_HR_graph_lite_STR_M</tag>
<txt>Herzfrequenzkurve</txt>
Thanks.
The next time I ride I will set a page up with it.
I would say it is a UI bug, but not one I could reproduce. I rode for 2 hours today and the data field work without issue for me.
Hey, thanks for testing on your device, meamwhile I set back all profiles and built them new, now it is working, creasy but it works. I also make the update to 4.10, but there is a fix for wlan only.
You don't need the CIQ Data Field for that to display. You can find this already implemented under the data fields -> Graphs Section.
I used the garmin flied from the graphs section....
Sorry, had misread it.
