New Edge 1030 Plus Public Beta 3.19 Now Available
A new Beta software for the Edge 1030 Plus has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1030 Plus (3.19): https://www8.garmin.com/support/agree.jsp?id=15397
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 3.17 to 3.19:
  • Removed radar all-clear tone.
  • Fixed bug detecting VO2 Max. with wrist-based heart rate.
  • Fixed crash on power down and going to mass storage mode.
Changes made from version 3.14 to 3.17:
  • CIQ 3.2
    Added encryption for CIQ widgets and data fields.
    Added CIQ workout information support.
    Added CIQ data field alerts.
  • Improved radar all-clear tone user experience.
  • Added tone to end of FTP test to notify user of completion.
  • Fixed FTP test preview page showing incorrect data.
  • Fixed crash on map data screen layout configuration.
  • Fixed various other crashes.
Changes made from version 3.00 to 3.14:
  • CIQ 3.2
    Added CIQ 3.2 support.
    Added BLE sync support for the Connect IQ app.
  • Indoor Training
    Added smart trainer widget that includes Tacx Road Feel controls.
    Fixed course points for indoor trainer rides.
    Added the Virtual Partner to the map page when following course or activity on indoor trainer.
    Fixed issues with grade, power, and resistance controls for smart trainers.
  • Radar
    Added radar 'All Clear' tone. Setting is configurable in the radar sensor setting menu.
    Added instructions for pairing a radar in the radar sensor search menu.
  • Segments
    Fixed recurring 'Deleting Segments' prompt.
    Fixed updating segment leaders on sync.
    Fixed segment completion bugs.
  • Improved reliability of FTP auto detection.
  • Fixed turn by turn navigation while workout is active.
  • Fixed workout target boundary ranges displayed on the workout page.
  • Improved Livetrack reliability.
  • Fixed showing area name when cursor is dropped on the map.
  • Fixed false 'Climb Complete' prompts when riding a segment with ClimbPro.
  • Fixed retaining light network disable over power cycle.
  • Added support for metabolic calories in the activity file.
  • Fixed issue with smart eat and drink alert prompts.
  • Fixed other minor UI bugs.
Installation Instructions
  1. Connect your Edge 1030 Plus device to your computer using the micro-USB cable.
  2. Download and unzip Edge1030Plus_319Beta.zip folder.
  3. Copy the GUPDATE.GCD file from the Edge1030Plus_*** distribution folder to the \Garmin folder of your device's internal storage drive.
  4. If there is a GPS_*** folder, place the 006B310706.GCD file into the \Garmin\RemoteSW folder of the device. Please note, not all Beta releases will include an update.
  5. Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  6. If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_310.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  • The "all clear" tone has been removed from this maintenance release to ensure we deliver the best experience. We plan to reintroduce the all-clear tone in future beta testing.
  • Well that makes me sad, I installed 3.14 for that reason, and have found it very useful. Now I have to imagine in the next full update, it will not be there but there may be other features I would not want to miss out on, so I will have to choose. Can you not at least leave it there but disabled by default until you have solved whatever you are trying to do?
  • With 3.19 public beta; my edge 1030 plus doesn 't find the GPS signal with GPS alone and GPS+Galileo and lose the signal very often with GPS +glonass.
    It is a very big problem !
  • With 3.19,
    - Installation progress circle seems to be frozen at low percentage .. but keep patience it works fine
    - No problems detected
    - (Very) Fast GPS lock, (gps+glonass)
    - With external HRM (chest strap) no VO2 max
