Hi Garmin Support Team,
I am from Garmin Users from Edge 1000 and very happy since 2016, recently due to the Edge 1000 malfunction, and not able to get old model hence has purchased an Edge 1030 plus a month ago.
- Avg speed Issue:
- When u rolling 28.0 km/h and when avg speed says 29.0 km/h; and approaching traffic lights or the current rolling speed lower than avg speed, it will keep dropping like every 10-20 seconds from 28.0 km/h to 27.9, then 27.8 km/h then 27.7 and so forth.
- This is even more obvious specially when stopped means pause it will not drop and the number stays there but when rolling below avg speed it dropped especially heading to traffic light.
- I've speed sensor, ever since I got the edge 1030 plus, I noticed the avg speed keeps dropping like within 10 seconds from 0.1-0.3 whenever approaching any traffic light. It ever happens in my Edge 1000 before.
- Speed number keep up and down while rolling:
- I also noticed when rolling with the speed sensor the number always like up and down. For example, says cruising 40 km/h, then 1 second showing 20 km/h then another second back to 40 km/h plus-minus; then another second back to 19 km/h plus-minus, another second change to 40 km/h repeatedly.
- Wonder if this is the root cause which results in how it affects the average speed mentioned in #1.
This has never happened in the Edge 1000 in the past and this is the first time I noticed ever since bought the unit. I've been monitoring this for quite some time and been asking around those with Edge 830 and 530, so far I didn't get any negative feedback.
Kindly look into this and let me know accordingly.
Thank you.
Regards,
Min Yoon
