Hi,
Would like the ability to select which sensors are active on a activityprofile.
Using 2 bikes and one indoor trainer, 3 power meters. Would like to select from a list which sensor the profile should look for
Hi,
Yes, this would be great.
...but is not possible and not necessary.
Your Edge looks for „waked up“ sensors and connects to these.
Just turn on your Edge, wake up the sensors on your desired bike (rotate wheel, crankarm...) and off you go!
Your Edge will stop searching for other sensors after a while.
Not to mention that if there are several sensors that are awake you can chose the one you want. When adding sensors I gave them specific names for this very reason (Vector3, KICKR, Madone, SpeedConcept, HRM-Tri, TICKRXetc) in the event more than one is active
