Is there a way to set the default profile to a specific one, or the last used ??
My 1030 seems to be stuck using the MTB profile.....
Regards,
Regards,
It should just stay on the last one used.
You might need to back you settings up, reset the unit and restore your settings.
I've gotten into this state a couple times. It should always default to the last one you used. Doing a full reset fixes it as aweatherall suggests. The bad news is, that's a PITA. The good news is, it's a lot easier to do now than it used to be.
One thing I never tried, but would be interesting to see if it fixes it would be to save your profiles, delete them, and then add them back. No idea if it will work, but might be worth a try over resetting the entire device.
- with the 1030+ plugged in to the computer, save the .fit files from the Garmin\Sports folder onto your computer
- then either delete the files there or boot the 1030+ and remove the profiles through the device.
- copy those files to the Garmin\NewFiles folder
Next time you boot, it should re-add the profiles
