sensor drop
egde 1030 plus
sensor drop and hang up the unit. it works more stable with just few sensors and it seems that Varia light and radar is causing most drops.
  • I can concur.  It would appear, on mine, that the BLE from my 510 is conflicting with other BLE and dropping out 9 time per hour.
  • Same problem here and while the radar dropping is the most visible (because of immediately screen alert) I don't believe the radar is the problem  I experienced several total sensor drops and screen freezes in an area where my cell phone lost cell coverage.  I use Live Tracking.  My phone was obviously paired to 1030+ using BT.  I turned the phone (iphone 7) off and re-booted the garmin -- no more troubles for the rest of the ride.
    Before my next ride I paired all my sensors (Assioma Duo, Tickr strap, Varia Radar) to the garmin using ant+ instead of BT.  Made sure my phone was connected to the garmin and off I go.  No problems for the entire ride despite loss of cell coverage in some areas.  Live Tracking also worked where cell had coverage and resumed when coverage was lost and then regained.  (ymmv)
