After updating the firmware to version 3.00 the GPS has started to have a very low signal consequently the GPS track is highlighted incorrectly and the Strava segments do not start..
With the Edge connected to the PC try deleting the following 2 files off the Edge. (see below)
Disconnect the Edge from the PC. The Edge will rebuild those files.
Now reconnect it to the PC and see if it pushes the GPS software. If it does not I will pull the file from my unit and upload it here.
Delete
Garmin\Device.fit
Garmin\GarminDevice.xml
