Map routing
My new Edge 1030 Plus does strange things when I'm riding a predetermined course.
I always save from ridewithgps.com  in tcx file format. Then I copy the route into the "new file" folder.
When on the route, I'm always getting u-turns and alternative choices.
How can I just get the route I've programmed?
Yesterday I tried to follow a route I knew well and the 1030 Plus didn't want to follow it all the time.
Help please.
    Try using .fit file. succes
    Disable automatic rerouting.
  • U turns are are often a result of misplacing a control point on the RWGPS route - usually a control point placed on an intersection will in reality be positioned just off the intersection.  You can usually look for the U turn error in the RWGPS cue sheet.
  • Fit and tcx work exactly the same.
    GPX will also work the same for "turn guidance".
  • Turning off recalculation is a good suggestion.
    Note the the maps that come with the device are based on Openstreetmap (OSM) data. You might get a little bit better results if you use OSM maps when creating the route on RWGPS (there's a dropdown item at the upper right of the map).
    0 Former Member in reply to Former Member
    .fit file is te best small sized format. Garmin converts interrally all intoming files to .fit files (see your history and courses file)
  • For navigation (what this thread is about),  FIT and TCX work exactly the same.
    GPX (track) works exactly the same except it doesn't have course points.
    While there usually is no reason not to use FIT files, you might not be able to get the course as a FIT file (some sources will only provide the course as  GPX, which is fine because they all work exactly the same).
    Your suggestion to use FIT is not helpful because it misleads people to think there are magical differences. When, in fact, they all work the same.
    Yes, FIT files are smaller and what the units use internally but that doesn't matter for navigation.
    0 Former Member in reply to dpawlyk
    RwGPS has a standard .fit function
    It seems to me that if Garmin is using .fit files in the course and history files and they advise to use .fit files that this a good advise to Garmin users. All file formats are converted in the Garmin Edge devices to .fit files. Reason: efficient file size and therefor better performance.
  • However things "seem to you" doesn't change the following:
    "All file formats are converted in the Garmin Edge devices to .fit files."
    Yes, TCX, GPS, and FIT get converted to an equivalent FIT.
    Garmin converts these types because they all work the same!
