new Edge 1030 Plus - my experience - far awy from top model!
Got my new Edge 1030 Plus in order to replacce my old Garmin Edge 1000. Read a lot of finde things in Garmin product presentations but I have to state that Garmin did not a good job up to now:
1. display: compared with my old Garmin Edge 1000 or even the cheap Edge Explore model the display of the Edge 1030 Plus is an embarassement:
    first I thought the display is in a kind of stand by modus (one knows from mobile phones when they dims the display when not used) - however even when Display is
    set to 100% it is much darker, colours are pale and weak - both menues and cards, week contrast.
    One has to say it is better in direct sunlight, but this is not sufficient for a n outdoor gear! I thought at first that I got a defective Edge 1030 plus but we checked
    at the bike shop with 4 other new Edge 1030 plus - alls devices had the same weak display.
    Dont know what Garmin devekopers thought when implementing this bad display quality to their new Edge top model ...
2. Basecamp 4.7.2 - so the actual version - does not recognize the Edge 1030 Plus and is therefore only usable iwth lmited functions - distressing
3. Garmin Birds Eye maps: I was not able to chose the "Birds Eye" map download-function with the new Edge 1030 Plus - wherea no problem with the old Edge 1000 this function is not possible for the new top model - so one has no other choice than to upload custom maps - which often does not work properly with garmin devices (my old Garmin Edge 1000 often often crash/freezed during bike/mountain hiking tours when using kmz-maps.
This is really akward for such an expensive device: Garmin seems to sell their new Edge 1030 Plus without updating their own planning and map-loading software!
maybe Garmin can issue a statement to this point and a timeline when this issue will be fixed.
Without this feature and therefore solid maps usable the new Edge 1030 plus device is worthless for  long bike tours and especially hiking tours as one can see no paths/trails (forget the new trailfork maps - I checked them for some of the bike locations throughout Euroe where I have biked in the past - not usable).
Anyway I have to say: IF the mentioned 3 issues can be solved by Garmin (dont know how they will do this with the weak display built in)  the Edge 1030 Plus could be an excellent device:for the first time the built-in processor has a fine speed eg allowing card moving at amazing speed.The black colour looks great.
So hopefully Garmin reacts very quickly and change a current unsatisfactory device to a successful one. I use garmin Edge devices since  a lot of years and dont want to change the brand.
Greetings
ProfGruen
  • BINGO!!!
    Have so many thanks for that advice!
    Who in the whole world has come up with these MTB-themes?
    An option that only makes things worse. You can't believe...
    I renamed the file to Mountain.__kmf and finally my map is ok!
    I can't thank you   enough for that advice.
  • Absolutely incredible! You are a wizard. Now the colours of the cycle maps are really fine on my Edge 1030 Plus.
    Thanl you for the hint!
  • now Garmin please enlarge number and overall size of possible .kmz custom maps and enable BirdsEye for Edge 1030 Plus and I am superglad!
    0 Former Member over 4 years ago in reply to mcinner1
    Yes very good Thumbsup
  • I agree. The 1030 is OK on bright sunlight but way too dark elsewhere.
  • Ok the Edge 1030 Plus in the end becomes the device we all wish it to be:
    1. Display: colours of cycle maps amended (with hint Bernd R manually but will be solved with next firmware update according to Garmin Beta team).
    Display remains darker than former displays but quicker and much more responsive
    2. Basecamp and BirdsEye: full compatibility to BaseCamp and Uploading/Downloading of BirdsEye-maps will be enabled with next firmware update according to Garmin Beta team
    3. .kmz-file limitation: new message: this will be enlarged significantly from 100 tiles (3 MB max each) to 250 tiles ((3 MB each) with next firmware update according to Garmin Beta team mail to me this night This is  real good news for all who like to use individual  custom maps on the device and enhances the versatility of the Edge 1030 Plus.
    When all this will be fixed with the next firmware update my criticd are solved and I may remove my kind of very critical evaluation on the origin of this post
  • points 2+3 are solved now by new firmware 3.00.
    I have to check yet if BirdsEye tile show veightwr colours than custom maps but I am satisfied now.
    1030 plus is a recommendation!
    0 Former Member over 4 years ago in reply to BerndR
    Hi BR, where do I access the map themes file to amend the name? Is it through my computer, the device itself? Thanks for any help you can offer
