Problems with CIQ-datafield download
Something strange is happening if I want download (install) the IQ-datafield below which was built with SDK 3.1.9.
This datafield PRG-file has a size of about 60 kb.
https://apps.garmin.com/en-US/apps/2121b19f-e20f-44b0-8c85-fa750b804eb1
EDGE 1030 PLUS
Software:  2.30
CIQ-Version OnBoard:  3.1.6
The download is not carried out until the end. Only 26 kb (of 60 kb) are downloaded and a CIQ-LOG file is created  ( \Apps\LOGS ):
Error: Unexpected Type Error
Details: 'Failed invoking <symbol>'
Time: 2020-06-27T09:40:26Z
Part-Number: 006-B3570-00
Firmware-Version: '2.30'
Language-Code: deu
ConnectIQ-Version: 3.1.9
Store-Id: 2121b19f-e20f-44b0-8c85-fa750b804eb1
Store-Version: 14
Filename: A6R91652
Appname: 'HMs DIY #6'
Stack:
  - pc: 0x1000039a
  - pc: 0x100000f2
The strange thing is:
I was able to download this datafield a few days ago when it was still on SDK CIQ 3.1.7 built.
I can download and install this datafield on SDK 3.1.9 without problems on my "normal" Edge 1030 which also is on CIQ v. 3.1.6.
Only the combination EDGE 1030 PLUS and IQ datafield built SDK 3.1.9 does not work!
I have contacted the developer, he will have a look on it.
I have contacted the Beta-team, but they have not answered yet.
The problem is:
I don't know - is it a common problem for Edge 1030 PLUS when datafields built with SDK 3.1.9 are to be installed or is it a problem on the developer (SDK) side.
So I would be grateful if someone of you would install this datafield (HMs DIY Clone #6 - it must be #6!) and then check how big the PRG file is or if there is a LOG file.
Thank you!
  • I also just tried installing it and after syncing it wasn't being downloaded.  So I downloaded the 3.1.9 sdk and updated one of my own data fields from that.  I downloaded my data field which showed up immediately in the Gamrin\Apps folder on my 1030+.  the "HM's DIY" data field also showed up at the same time.
    I was then able to configure a data page with both data fields.
    Might be worth a try.  Download my data field, https://apps.garmin.com/en-US/apps/521d4940-2600-4bad-9c39-1d035d2049f2, and see if both of them start working.  Unless you have a Garmin Alpha, mine won't do you much good, but it might help determine if there is some oddity in the install process.
  • Thank you very much for your help. The developer of HMs DIY uploaded a new version to the store yesterday which resolved the issue. Thanks!
    Edit: just looked at your datafield. Dog tracker! Dear me, Alpha! I never knew there was such a thing...  Slight smile
