Strava Live Segments not popping up
All of a sudden Strava Live Segments stopped automatically popping up. I rode the same route as a few days ago and not one segment popped up, but a few days ago 4 segments along the same route popped up anyone else seeing this and know how to fix it?
  • Check and see if the segments in question have  a -.25% average or more, Strava stopped syncing what they deem dangerous segments. I had several of mine stop popping up and was able to just grab them from a backup of my Garmin folder. If you have a backup of the segments folder just copy them back to your newfiles folder on the Edge.
    0 Former Member over 5 years ago in reply to bloom34
    They are pretty flat segments and they show up on my 1030 plus and are enabled, they just don’t pop up when I approach the segment,
  • Mine showed flat as well a 0% average but mine were not transferring to the device so if they are on you device it sounds like a different issue. If you go to navigation and then show map when you pan to the location of the segment is it visible? Could the GPS track be off where it crosses the start of the segment? support.strava.com/.../216918187-Segment-Matching-Issues
  • Segments that have no options "Set a Goal"  do not synchronize in 1030+.
    Unable to manage maps.
    You cannot transfer a profile, everything has to be done manually.
    Impossible to transfer totals kilometers, even manually.
    Another embarrassing Garmin performance.
