Stuck in loading
The 1030 Plus worked until GE tried to update maps.
Then the unit gets into loading, stops, restart and go back to loading.
Tried to mount it as mass storage and looked in New Files, nothing there, (tip in other posts).
What to do?
    Solved the issue. Removed maps accordig to other post, was then able to upgrade to 2.30 using Garmin Connect (was able to connect although it was in "Loading").
    Seemed that 2.30 did the trick, it now works.
