I have a Garmin 800 with a new magnet less speed sensor, every time I go up a bridge, ride on a bridge, down a bridge the sensor speed just drops every few minutes. If I'm on flat ground, no problems. Basically it acts like its auto paused even though I'm moving. I tried a new battery, front wheel, rear wheel, cleaning the contacts. If I turn off auto pause, I can still see the speed drop, heart rate drops to 0, then it resumes. If I disable sensor all together, everything works as it should. Not sure what else to do with this.
Thanks.
