HELP Garmin Capteur SDM4 (Foot Pod)
Hello everyone, sorry again for my English, I'm French.
Currently I have a watch Garmin 920XT works well since i set a trouble with a guy from the forum.
Recently I have a Garmin SDM4 sensor (Foot Pod) but I do not know at all how the couple.
I went into the settings and I have chosen / Settings / Sensors and accessories / All search and nothing happens.
I also tested with speed / cadence but similar.
I said that the sensor is new.
On the net Garmin SDM4 sensor (Foot Pod) is compatible with my watch.
Can you help me?
Best Regards.
  • Most sensors including the footpod go into a sleep mode after a period of no activity. Before attempting to pair it to your 920XT, you need to clip the footpod to your shoes and walk around for a few seconds. If that doesn't work the footpod may need a new battery, or you may have a defective footpod. I believe that the speed and cadence sensors also go into a sleep mode, so you will need to wake them up by spinning the wheel a few revolutions.
