I have put the new magnetless spped sensor to my front hub dynamo.
Now I do see extreme spikte with up to 120 kmph and the automatic wheel calcultion is working wrong as well.
As soon as I disconnect the sensor and the speed will only be calculated via GPS everything is fine.
I tested it with a Forerunner 620 and an Edge 1000.
http://connect.garmin.com/activity/543217680
http://connect.garmin.com/activity/543223058
Please help! Can a hub dynamo induce such effects? Or might the sensor be wrong?
I have a second new speed sensor on my road bike with a normal (non dynamo) hub and everything is fine.
