Speed Sensor 2 measurements stopped early
Hello,
I bought a new speed sensor 2 and mounted it on the rear wheel.
By now I used it 5 times. In 2 of 5 rides (10 km) it did not record the whole tour. It actually stopped recording after 0.15 km and 0.43 km.
Version is v4.10.
Is there something I can do to fix it? Are there others having similar issues?
Best regards
Ben
  • If that was my only purpose I'd return it to the seller. Its clearly not working as it should.
  • I’ve been investigating this issue for the past two weeks, and I believe I’ve identified both the root cause and a workaround.
    My hypothesis
    1. Whenever an ANT+ or Bluetooth connection is active, the sensor stops standalone recording to prevent duplicate activities.
    2. When the sensor is paired with a phone over Bluetooth, the Garmin Connect app periodically connects to the sensor to check for updates, synchronise data, etc (even in background, when application seems to be closed).
    Effect: If your phone is near the sensor, Bluetooth wakes up every few minutes, so standalone recording is either interrupted or never starts.
    What I did to confirm this
    • Unpaired the sensor from my phone and removed it from the Garmin app.
    • Rode many segments throughout the week.
    • Re‑paired and reconnected my phone to the sensor.
    • All activities from the past week synchronised correctly and appear to be recorded properly.
    This doesn’t change the fact that the product software is poorly designed:
    • It records every wheel movement, regardless of distance, with no configurable threshold, so I ended up with several 50–60 m “activities” just from moving my bike around the garage.
    • When I stopped riding, the device closed the activity after a few minutes (apparently four) and started a new one when I set off again. The feature itself is useful, but there should be an adjustable time‑threshold setting.
    Tested on software version 4.10 of the speed sensor 2.
    I hope some other frustrated users will find this information useful :)
