Hi to all,
I have some problems with the synchronization step on my edge 540 via wifi connection.
I've set properly the correct password on my device from garmin connect and the test working fine but when i try the sync from edge i receive the error: Synchronization failed.
Can you help me ? Can you suggest the solution of this problem ?
Many thanks in advance.
