Speed Sensor 2 on Alfine 11 rear hub?
Hi, I’m changing bikes to a city bike & need to fix a Garmin Speed Sensor 2 to an Alfine 11 rear gear hub (circumference 25 cm) or, alternatively, to a Shimano dynamo front hub (18 cm). The rubber band attached to the standard casing is way too short. I m going to try cable binders, but was wondering whether someone here has already found a working solution for this?
Thanks Wolfgang
