Speed sensor 2 not waking up
I got cadence and speed sensor 2, the cadence is working perfectly fine. However the speed sensor is not waking up at all, every time I need to remove the battery wait a couple of seconds and put it back in order for the sensor to work. Kindly advise, as this is my second sensor I try and the same issue I have.
  • I have had the same problem with two copies.  My guess is that there is a serious design defect.  The red and green lights do work when I open up the case and hold it closed.  But then when I twist the cap to close it, nothing.  I have tried to use tape to better hold the battery in place.  And i have tried to slightly bend the side and bottom battery contacts outward.  Still nothing.  I guess I will once again return the thing,
