Edge 520 Speed Sensor Data to Garmin Connect?
For the Bike Speed Sensor included in the Edge 520 Bundle (520, BSS, Cadence Sensor), is there any way to get the wheel size data saved to the Edge so that it can be uploaded to G-Connect?
It seems, the only way to get at it is, while both the Edge and sensor are on and active and linked, is to scroll through the Sensor Data fields on the Edge.  Also seems that the data is not saved in the Ride Data.  Is this correct?
I would like to have the Wheel Size info more readily available to help a friend (with same size tires & air pressure) calibrate his Cateye (non GPS) computer.
And yes, I have repeatedly suggested the he just get a Garmin-GPS unit!
Thanks much!
/r.
PS - Obviously, the Cadence Sensor data is saved on the Edge and uploaded to G-Connect.  I'd like to get the same functionality for the Speed Sensor!
