Hi Garmin Team,
I'm riding/descending with my left (non-driveside) foot in the rear, where usually you also position your Speed&Cadence-Sensor.
This frequently results in abnormal high max. Cadence values as it triggers the sensor mutliple times when you raise/lower your foot a bit while coasting over bumps.
Its especially a problem on my MTB but also on my Gravelbike
would be nice to have cutoff-values for min and max Cadence, located in your profile settings in Garmin Connect or on your Device so you get an better average on your actual pedaling (without averaging in the coasting time and those errors)
otherwise a MIN 30s AVG and a MAX 30s AVG would be awsome (so you see when you are dropping to low, putting strain on your knees or actually making progress on spinning faster)
Using Edge 130 and Vivoactive 4s
Greets Lea
