Devices/Sensor Description:
The Garmin ANT+ Speed Sensor is at least 5 yo, it came originally with the Edge 1000 bundle, and has always worked perfectly. It's the type you hook to the center of the wheel with a rubber band. I just put a new battery in the Speed Sensor for the 2020 summer cycling season. I recently acquired a Fenix 5X sport watch and I got the same behavior when the Speed Sensor is coupled to the Edge 1000 and the Fenix 5X.
Problem Observed:
When I am heading South/South-West, the Sensor Speed is accurate compared to the GPS Speed.
When I am heading North/North-East, the Sensor Speed is about 2x the GPS Speed.
This behavior is consistent with all test setups:
1) Edge 1000 Sensor Speed - Fenix 5X GPS Speed,
2) Edge 1000 GPS Speed - Fenix 5X Sensor Speed,
3) Edge 1000 Sensor Speed - Fenix 5X Sensor Speed,
4) Speed Sensor hooked to the front or rear wheel,
5) Wheel dimensions set manually or set to auto.
How can the Heading affect the Speed Sensor output? I though the Speed Sensor was just counting the number of revolutions per sec and the Devices were converting in speed based on wheel dimension.
Is it possible there is the same software bug in both the Edge 1000 & Fenix 5X that miscalculates the speed based on the Heading?
Is the Speed Sensor broken and need to be changed? I don't want to spend another 75$ just to find out there is no problem with the Speed Sensor.
Something doesn't ad up here. Very weird bug.
For now I have to deactivate the Speed Sensor and ride on GPS Speed only.
Suggestion anyone?
