I purchase a Garmin strap transmitter at the end of 2018. This was to last 3.5 years with the installed battery. Recently, after about an hour of riding the transmitter showed an abnormally low reading. I checked the battery, which was not exhausted, but I installed a new one just to be sure. On the next ride exactly the same thing happened.
This same situation had happened on my previous strap.
Then on my next ride I used a new transmitter purchased in fall 2019, and it worked normally.
My rides are of normal duration and frequency so the transmitter should have lasted at least for 3.5 years. The problem is that even with a new battery installed the problem persists.
Any recommendation on this issue are appreciated.
