I've bought the SS2 a couple of weeks ago, and since then all the cycling I do gets registered twice whenever I use my Garmin Edge.
It makes kinda sense because by default I'd expect both the sensor and the Edge to record an activity separately. But I'd hope the platform would be a bit smarter than that... Seems I have to either never connect the sensor, never use my Edge, or everytime I use the Edge, delete the sensor activity.
Am I missing something? Some have suggested to disconnect the sensor from the Connect app when I use the Edge, but it will still sync the activity next time I connect it so I don't see the point.
I paired the sensor using Garmin Edge using ANT+ though. Should I pair it using Bluetooth instead?
Here's an example:
https://connect.garmin.com/modern/activity/4115099862 recorded with the Edge
https://connect.garmin.com/modern/activity/4134064125 recorded with the SS2
