Hi!
I'm getting some impossibly high speed readings when cycling on some parts of a canal in my hometown (the canal is Regent's Canal in London). I haven't tried all the canals around, but the readings go off as soon as I enter certain parts of the canal towpath, systematically.
See this activity: https://connect.garmin.com/modern/activity/3145511677
The sensor goes completely bonkers as I enter the canal, and comes back into its senses as soon as I leave it. Some parts of the canal it doesn't happen, but some parts it does it every time.
I've got it with the sensors on both my bikes, plus a replacement one... So three sensors, and as many devices (Garmin Edge 1000, Garmin Edge Explore and Vivoactive 3). Whatever the combination, I'm getting impossibly fast readings (between 90 and 120km/h) on some parts of the canal, systematically.
I thought it could have something to do with being near the water? Like some sort of echo or something? Not sure why some parts of the canal and not some others either...
It seems like a design flaw, is there another type of sensor that wouldn't have that problem? I'm having to disable the sensor on my commute, which is quite annoying. Also, would be nice if connect could fix speeds and distance based on GPS data!
