I can not connect my Garmin GSC-10 Speed ??/ Cadence Sensor with my Garmim 910XT
Hello I bought a cadence sensor and speed in 2007 Garmin GSC 10. But I never took it out of the box to use. Now I went to use it, changed the battery for a new one, the green and red lights without the sensor being mounted on the bike are working but it is not pairing or connecting with my garmin 910XT. When I try to set it up in the Bike1 menu I say it has speed and cadence sensor but does not detect. What could be happening? It is brand new and has never been used. If anyone can help me, thank you very much.
I am doing exactly as it says here:
https://support.garmin.com/en-US/?faq=IHfTaYGKA08liMhD4BtxLA
Sorry for writing but I'm using google translate :-)
Another question: For the clock to connect is it necessary to have all the sensors installed on the bike? Like this video? https://www.youtube.com/watch?v=Wg19nLxToXs or if I approach the central unit already connects?
    Are you passing a magnet over the speed or cadence sensor before trying to pair? The GSC-10 goes to sleep if there are no trigger inputs.
  • I am using exactly the same combination (FR910XT & GSC-10) on my bike. It works absolutely perfectly for me.As I recall, I had my wheel turning while I paired so that the GSC-10 was awake.
