Amateur's Question About Speed & Cadence Sensor
Hi All!
I am thinking about getting Garmin's Speed & Cadence Sensor set to use with my Vivoactive HR and had a couple of questions for which I couldn't find the answer. I am hoping you all don't mind lending your expertise.
The purpose I have in mind for the sensors is so that after a Cycling Activity I can go on Garmin Connect and see what my cadence was at certain speeds or heart rates or elevations.
To better explain...
In Garmin Connect I can go to Activities, select a Run Activity (for example) and see four horizontal graphs. They are Elevation, Pace, Heart Rate & Run Cadence. I can drag the cursor across and a line shows up across all four graphs. I can then see what my heart rate or speed was at a certain cadence or elevation, etc.
Does the Speed & Cadence Sensor allow the data to be uploaded to Garmin Connect in a similar fashion to the run described above?
Thanks For Your Guidance! It's much appreciated.
Paul
