I've chatted with support and they suggested that the watch is still learning battery drain what explains illogical numbers.
It is possible because it has a few days and I've never charged it yet so maybe it will fix itself...
Let see...
Let see...
During a 5-hour hike, the battery dropped from 98% to 15%, with only GPS turned on. I can’t figure out if it’s my Apple Watch or Garmin — what could possibly be going on in the code to drain the battery that fast?
Satellites: GPS on…
Since my last update, 2 days ago, the battery Is lasting less than 48hrs, drained 70% in last than 24hrs Without using for any activity, any help???
Hi,
unfortunately the bug reported in https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-955-series/306973/forerunner-955-fw12-23---very-serious-eternal-sync-bug---rapid-battery-drain is still present on FW12.27.
This afternoon the…
After V11.90 the drain drain issue started.
V12.50 corrected it.
Now it is back with V12.70.
First ride with this new firmware and the battery was empty after just 4 hours.
Another problem on the latest firmware. Today during skiing battery drained from roughly 25% to dead in ~2.5 hours. Super frustrating.
After the latest update, I have noticed battery drain. When I updated my watch on Friday Aug. 11th, my watch was at 100% when it was finished. Today, it's already down to 84%. This morning, it was at 88% - 90%. Before the update, I was getting 12 - 14…
Friend of mine had battery drain during ultra. The battery died after 29 hours in gps only mode. Maybe this is the reason, he had inreach mini connected...
It depends a lot on your watch face choice, as well as which model you have. I have the 6x Sapphire and only lose around 4%-5% per day, but that's partially because the watch has a larger battery. I run three times a week for about an hour each run…
