Just uploaded the software version to 20.29 and still have massive battery drain.
anyone else?
anyone else?
I was using 22.40 update and everything was perfect with respect to battery. However when I updated to 24.10 the battery drains faster every hour. Previously per day it would reduce 4-5% with just smart watch mode. No GPS or BT. However now it is draining…
Terrible battery drain of about 1.2% per hour since I installed 12.07 (people had reported a similar battery drain with 11.16 but I wasn't using the watch at the time).
I'm going for a 1h15 run with 59% battery, hope it sees me through the run !…
My Forerunner 245 just got the 9.00 update and I immediately started having issues with the battery draining more quickly than usual.
I've had this problem before, and a Garmin technician had my connect the watch to Garmin Express, sync the device, and…
I dont have a lot of data yet but it seems to me that battery drain could be higher with this beta version. I am going to charge my watch to 100% and monitor.
Venu firmware practices are a disappointment.
It's the same on Vivo* series as well....
Like yours my battery drains with no activity, probably less than a day. The LED's are so bright I can use it as a flashlight. The HRM still works just need to power cycle the watch before I go running otherwise it's not accurate. I now only turn the HRM…
My vivoactive 3 battery is draining about 5% per hour when in watch mode. Charged it yesterday afternoon and it was at 100% as of 4 pm. Went for a 5 mile run last night, battery was at 40% by this morning and by lunch it was at 25%. I have not changed…
I have the same issue few months now - battery drains to fast after 2 hours.
