• RE: 25% battery drain overnight on 3.6
    Dreadful, maybe you made a typo but 100-85=15
    I have random quick battery drain. Sometimes over night and sometimes in a span of a few hours during the day.
  • Marq Adventurer Gen 2 Battery Drain
    I've recently started experiencing extreme battery drain on my Marq Gen 2 Adventurer. In normal watch mode the battery would last 12-14 days which has now halved to around 7 days. Software is always up to date with the latest Beta (present 23.08). If…
  • Battery draining quickly after 4.30 firmware update
    Since I installed the 4.30 firmware update and recharged the battery to 100% last night, the battery drained to about 40% in about 18 hours with no GPS activity. Anybody else experience this?
  • 12.22 - Extreme battery drain after gaming activity
    After using gaming activity at 6PM, with no other watch activity, battery draining by 30% by 9AM. Similar results after several other usages. PC is turned off so no persistent Bluetooth connection.
  • RE: Battery drain fast Garmin connect Android
    Massive battery drain on iOS as well.  It started around January and has not been fixed yet.  You must contact Garmin customer support and file a case with them and submit diagnostics.
  • RE: Fast battery drain / connectivity synching issues (sometimes).. more details enclosed
    Just following up on this. I noticed higher battery drain during Sunday so I charged my Epix 2 to 100% at 9:30pm last night (Sunday). At 6:30am this morning (Monday) it was down to 89%. This is the same behavior I saw during the betas when I was experiencing…
  • RE: Garmin pay - time out battery drain
    I use Garmin Pay a lot (90+ percent of all my payments), and I have not noticed increased battery drain because of it. Definitely not anywhere close to 2 percent per hour.
  • RE: Fenix 6 pro Major battery drain
    Anybody else seeing this issue?
    give it a try with the search
  • RE: Battery draining quickly after updating it to 14.31
    Rolling back to 13.22 using the method described worked for me.
    It's been 2 hours and I've not lost any percentage of batt and I have Bluetooth and wifi on and hr monitoring on my display. Aod on.
    For what it's worth. I think epix pro users are…
  • Fenix 5X HRM battery drain
    Hi,
    I have problem with some kind of HRM issue (probably). Maybe month and half ago after connecting to pc begun problem with HR sensor. Wrist HRM stopped flashing during inactivity and light is still in "on" mode even with Automatic mode. It's ok, but…
