• Battery Drain over night
    First of all, this is my first Bug report and I am all new to the Beta Enrolment, so bear with me if I don't provide all of the necessary Information. I will though if pointed out.
    Yesterday I went to bed with a charge of 30% and a 3 day estimate…
  • Increased battery drain!
    After the update, 5 hours passed - the battery sat down by 5%! It didn't happen before! It turns out that in 24 hours the battery will sit down by 24%. A full charge is now only enough for 4 days?!
  • Lily battery drained
    Good day,
    Please assist, I charged my battery full and at 9:00 the following morning the battery was sitting at 23%. This issues started since 2 weeks ago and then if seems fine, now its back to before.
    You assistance would be much appreciated.
    Nancy
  • Battery drain issue
    Since the last update I seem to have lost some battery life. I have the 6 Sapphire and it's only a couple of years old so I'm guessing it's the software and not the internal battery. Anyone else experiencing this?
  • High battery drain
    After recent updates, the battery was losing ~11%/24h in smartwatch mode. Last day it is already 20% with one activity with GPS (only GPS/ 1sec rec.) lasting 22 min. I had battery saver mode on overnight (with HR on).
  • 20.22 battery drain
    The battery level on my 7X Solar has been plummeting since 20.22. With my settings I normally do around 10% a day. At around 06:00 this morning I was on 51% and the battery has dropped to 32% at 17:20. No settings have been changed since the download…
  • Battery drain 13.34
    I checked the battery usage of the watch, and it seemed normal with the current Beta (13.34). Until yesterday evening, where the watch lost maybe 10% of battery over night. I rebooted, and now the battery consumption looks normal again.
    On the graph,…
  • Fenix 6X Sapphire - Abnormal battery drain
    I purchased the watch about one month ago, I found the first one has screen quality issue the second and Garmin changed a new one for me. However, recently I found the one I am using now has battery issues...
    Everything looks good in the first two weeks …
  • Constant Battery Drain
    I’d had a few Missing Right Sensor Issues which I sorted by cleaning all the contacts with Alcohol.  I then put in a brand new set of Duracell Dl1/3N batteries.  1 week later and the pedals wouldn’t wake up at all.  Removed the batteries and checked…
