• RE: Android battery drain on connect App.
    My battery drain on the S25 Ultra from the Connect app is daily around 0,5-1%. Try updating Google Play..
  • 12.59 - Battery drain overnight
    At morning 5:50 AM I was really confused when I got to charge my watch last but I think it was on Saturday, but the  battery seems to be low - 30%.
    Now 9:12 AM I got 20% battery, without using the watch - watch only on wrist, some notifications, nothing…
  • RE: Battery drain more than 30% pee day
    Is "pee day" battery drain Found in Body Battery?
  • Rapid battery drain on 17.21
    Since updating to 17.21 my battery is draining really fast. During an 8 hour sleep in sleep mode it went down ~20%. It was the same during a day wihout any workout or music.
    There were no problems on 17.18.
  • Rapid battery drain from 25%
    For the past month the watch turns off when reaching battery levels around 25%, it suddenly jumps to 1% and then 0% and shuts off without prompting to activate battery saver.
    I think the watch is overly optimistic when calculating the battery draining…
  • Connect App Battery Drain
    I have an iPhone 13 and used to keep the Garmin connect app open however at some points, randomly, I'd find my phone very hot in my pocket and check the battery usage to find that the Garmin connect app had just drained about 20% of my battery in less…
  • RE: Battery Drain in the last few versions
    I have noticed quicker battery drain in the last few beta drops.   I just got 6.9 days with 0.6% battery drain per hour in 11.22 beta.
  • RE: Battery Drain on Venu sq Music
    Hello! After you have rebooted your watch can you tell me if there is a difference in your battery drain?
  • Battery drain Venu SQ during swimming
    My Venu SQ has an extreme battery drain during Swimming (pool) activity.
    Within 30 minutes the battery went down from 25% to 0%. During normal use (with running/cycling) the full battery last for 4 days.
    GPS is not used.
    What is using so much power and…
  • RE: Battery drain on Vivoactive 3
    I've found a culprit - Wifi Sync is getting stuck, keeping the Wifi Radio active and that tanks the battery.  Rather than hijack this thread, I've posted here about it.
    Maybe it's not related to your battery drain, but yea, I've certainly noticed…
