• High battery drain while pausing / interrupting an activity
    I use an Epix 2 with V10.39.
    I recognized, that while pausing / interrupting an activity, there is a high battery drain, much higher than in normal watch mode. But what is the difference to the normal watch mode? GPS and all needed sensors for activity…
  • Backlight and battery drain?
    I have my backlight set for auto gesture on all the time. Timeout set at four seconds. back light level at 50%. Will that place a big drain on my battery of my 5S?
  • RE: Venu 2 Plus : Battery Drain Issue!
    Hello all,
    We currently have a Beta software that many (but not all) users have found resolves their battery drain issue.  Please see the link below to install this software and be sure to let us know (in this thread) if this resolves your battery drain…
  • RE: Edge 1040 Battery Drain
    I had an issue about ten weeks ago when (with nothing in my setup had changed, and the only significant difference was that it was my first ride with the device outside of the United Kingdom) my device used about 50% in one two-hour ride, which is about…
  • Sudden extreme battery drain
    Hi there,
    I’ve had my forerunner 235 for 3 years. Have never had issues with the battery. Suddenly about a week ago battery started draining suddenly. Ie one morning after leaving the watch uncharged overnight with substantial charge i found it dead…
  • RE: Battery drain issue with 6.90
    I had no issues with support. I too had severe battery drain . It happened about two weeks after the last update. They had me try a few things. When that didn’t work they said they would send out a replacement
  • RE: Excessive battery drain since last update
    How do I see % battery drain stats? I searched all through my watch settings and couldn't find it
  • Software update 3.00 - Battery drain
    Hello,
    I updated my Venu Sq to the newest software version, which is the 3.00 if I am not mistaken, and since then I am experiencing the serious battery drain on my watch. Normally, I have been using them up to 1 week, depending on the number of activities…
  • Battery drain 25% in 2 hours watchmode
    Again massive battery drain in watchmode.
    In 2 hours fresh after charge to 100% im now by 75%
