• Beta 16.13 Battery Drain + HR stopping
    wondering if anyone on Fenix 7 Beta 16.13 has had issues with severe battery drain and HR sensor stopping. Was on the beta about a week when one day there was no HR. Restarted the watch and the HR reappeared for awhile and then stopped again. then the…
  • Battery drains very fast recently
    Hi Garmin,
    I used to charge my Instinct 2 Solar about every twenty days and I was happy with its battery life.
    Recently I have found the battery drains very fast like every two days. One moment it shows the battery life is 20 more days and 2 hours after…
  • High Battery drain and sync issues
    I am experiencing a issue where after every workout my watch will sync the event to my phone however once that is done it no longer connects to the phone and the battery drains significantly I've seen it drop over 50% within the same day.
    If I restart…
  • RE: Battery Drain so fast
    I have the same problem. After updating the software 9.33 epix stay charged 4 days, which before held at least 10 days.Is very annoying because they are the same settings and from what I read not all have this problem with battery life.
  • RE: Severe battery drain after update 12.20
    Since i made a soft reset, my 6x seems works fine without this huge battery drain.
  • Battery drain, iOS11.4 / latest GC
    i'm not sure whether Garmin Connect or iOS 11.4 is to blame, but in the past week, i've noticed that my battery is draining quickly even when i'm not using my iPhone at all. when i inspected the Battery usage, i found that the Usage and Standby time were…
  • RE: Battery Drain Using Garmin Connect Mobile
    Battery drain
    Also my phone battery is drained since the last update from Garmin Connect Mobile app last week around 14 april 2017
    it empties twice faster than normal
    Fenix 3
    Garmin Index Smart Scale
    Sony Z3 compact
  • Battery drains in a day
    I don't know if this is related to some of the other software issues I've seen posts on, but about 2 weeks ago my Forerunner 235 suddenly started draining the battery in a day (or overnight). I got a new phone around this time, so I thought it could have…
  • GPS modes and battery drain
    I have a 5s plus. My battery life is decent when in normal usage, but gets completely drained whenever I use GPS.
    I tested all different modes, GPS only, Galileo, Glonass, Ultra tac. It does not seem to make any difference. Basically it is down to 4-5…
  • battery drain after 20 %
    Hy
    After 30 % or under 20%  the battery down very fast (when i active battery save mode)
    i don't understand big drain of
