• Battery draining quickly
    The battery of my watch seems to drain weirdly suddenly (had it since april). 12 days ago it was around 65% in the morning, then I biked to work (15 mins), and saw at the end of it that the watch gave 0% battery. Hadn't seen that before. It died after…
  • RE: Battery drain on the V4S - again
    Thanks for your advice. I will try it but since yesterday battery drain is normal... (0.5%/h)
    It is possible that when I charge watch from charger battery drain is biger than when I charge watch by laptop USB ?? I notice something like that...
  • RE: Instinct - battery drain after 6.60
    insufficient AC-fraction filtering at lowcost chargers
    In theory, yes. But I do not think this is often situation, especially when the charger is loaded only by 180mA.
    how do you get this screen
    Test mode, see https://www.youtube.com…
  • RE: SW 4.00: 50% more Battery drain
    I have Android 10.
    thanks!
    @all: hope we can sort this out, that only useres with Android 10 have the prob with battery drain?
  • Post-activity battery drain
    I've always historically had very good battery life with my 6X, and was curious why some people have reported terrible battery drain issues. Last week, I experienced it as well, and I figured out what was causing it, so I'm hoping this helps others and…
  • Massive Battery Drain
    I'm using Tactix Delta Solar. It has been 3 months with this massive drain. I updated my watch 24 hours ago to 22.83. But the issue is continued.
    From 100% battery to 45% In 24 hours :
    No GPS
    No Activities
    No Wifi
    No Pulse OX
    With Battery Saver Mood during…
  • Huge battery drain with v2.27
    Something has happened that is causing heavy battery drain, especially overnight.  For the last few days, I have changed the configuration, charged the watch during the day, and by the next morning have been down to about 60% battery, having used 40% in…
  • 6.90 battery drain is twice as fast
    My VA3 has been stable and doing well with just 15% battery drain per day very consistently.  Instantly after 6.90 installation the watch now drains at 2.5x that rate.
    Has anyone else that did NOT have battery issues before 6.90 now seeing excessive battery…
  • Battery drain after workout
    My battery is draining like crazy on my vivoactive 4 after recording a training. I've restarted the watch multiple times after multiple workouts buy it doesn't stop. I suspect it has something to do with the whrm because that's blinking like crazy.…
  • RE: Sleep pulse Ox and battery drain
    You are absolutely right. Had forgotten the waring message in GC about the battery drain.
