Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Excessive Battery Drain
    alex.pull
    alex.pull
    It's Puls Ox that drains battery, I've disabled Puls ox on my 6s pro and now I'm getting 7 days with everyday training.
    I'll save the Puls ox feature for mountains and Covid19, don't really need it every day.
    • over 4 years ago
    • Wearables
    • fēnix 6 Series
  • Vivoactive 5 software update 12.10 battery drain
    6598805
    6598805
    Significant battery drain with Vivoactive 5 after I got an update this morning. Battery drained ~40% in the past 7 hours just with walking and casual activity. Not sure if this is a problem others are experiencing?
    • 8 months ago
    • Health & Wellness
    • vivoactive 5 Series
  • Battery drain after a workout
    AndreaEsposito
    AndreaEsposito
    Hello all,
    In the last days, after the map update to the last version, I’ve noted an huge battery drain after a workout with the gps (run for example).
    If I shut down the watch the problem it’s solved until the next time.
    I’ve reset completely…
    • over 1 year ago
    • Fenix 6/Enduro/Tactix Delta/Quatix 6/Marq
    • Community Discussion
  • Battery drain in 9.31
    HugoParedes
    HugoParedes
    Since I’ve updated to the latest beta, 9.31, the battery has been draining more than usual. I haven’t done any workout since then (24 hours ago to be precise) and there’s a drop of 12%. Usually it would drop around 5%.
    • over 3 years ago
    • Fenix 7 Family - Public Beta Reports
    • Public Beta 9.xx
  • RE: Battery drain after update to 7.10
    MartinB
    MartinB
    I also noticed quite a different behavior of the battery after the 7.10 fw update.  My battery drain is fine in SW mode, until I do an activity. During the activity, it is much higher than previously and than expected (Around 10% per hour in GPS mode without…
    • over 6 years ago
    • Outdoor Recreation Archive
    • fēnix 5 Plus Series
  • RE: FR245 Music battery drained overnight
    dafroggie
    dafroggie
    I did a restart and it seems to have resolved the issue of a battery drain that is a little under 24 hours. Perhaps you can try that too?
    • over 3 years ago
    • Running/Multisport
    • Forerunner 245 Series
  • RE: High Battery Drain - Potential Workaround
    erik29gamer
    erik29gamer
    I have done this several times over the past few days and my battery drain is still excessive. That said, thank you for continuing to work on a fix!
    • over 5 years ago
  • RE: Battery drain after the most recent beta?
    JoMiSan-Tokage
    JoMiSan-Tokage
    No problem with battery here on Epix Pro 51mm
    • over 1 year ago
    • Fenix 7/Fenix 7 Pro - Epix 2/Epix 2 Pro - Enduro 2 - Quatix 7 - Marq 2
  • RE: Battery drains fully over night
    bluefish
    bluefish
    https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/marq-gen-2/339361/battery-issue-on-aviator-gen2
    https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/marq-gen-2/334489/battery-draining-on-aviators
    • over 1 year ago
    • Wearables
    • MARQ (Gen 2)
  • RE: Battery drain during scuba diving
    Volker
    Volker
    No heavy battery drain occured, only down to 97% after one hour. But maybe my attempt is not comparable to underwater behavior. So (again) my recommendation: open a support ticket.
    • over 2 years ago
    • inReach
    • inReach Mini 2
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
