• Battery drain
    It looks like the update to Garmin Connect is keeping my phone awake quite a bit. I've noticed a significant decrease to battery life. I've run Google's battery historian and Garmin Connect is on top of the list.
    Has anyone noticed the…
  • Battery drain
    Hellο, my fenix after 22.83 firmware uses 6.5%/hour of the battery having the same configuration, when it is idle.
  • Battery Drain
    Did a 2 hour and 30 minutes ride and everything was spot on including battery that went from 100% to 93% which is awesome.
  • Battery draining on quatix 5 sapphire
    I just got a garmin quatix sapphire and the battery drains very fast what should I do on this to keep it going
  • Battery drain after update to 8.10?
    Do you have any experiences with the same after update to 8.10? With 6.10 everything was OK.
  • Battery Drain
    Went on a 2 hour ride and battery went down to 83% when before for the exact same ride it would read 92 or 91%
  • Battery Drain
    With the 27 beta today I did a one hr TR indoor workout. Battery dropped from 84 to 66% in that hr. Post beta install I did do the forced reboot by the way.
  • Battery drain
    This night, the battery goes from 20 percent at 3:00 am to 12 percent at 7:00 am. I slept during this time.
  • Battery drain
    3h15min long trip and only 62% battery left (without navigation), standard setup - radar+hr+speed senson+power meter
    in v21 it was around 8% to max 10% per 3h trip
