in my F6X Pro is all ok no Battery Drain, now with 5.0 seems all perfect, very happy with new soft
After a Firmware Update, no matter whether beta or full version, I do a manual reboot and after this get a GPS fix because I have several widgets which need a valid GPS position.
So far no problems with battery drain after an update.
Best regards
di…
How much percent per hour fenix 7 sapphire solar drain during run? I know solar recharging… but i mean average. (With multiband and stock backlight settings)
This is different to the other battery drain issues. I had battery drain issues previously and my watch was logged by Garmin. I've had no issues since previous software updates however this new reboot issue has caused battery drain issues to come back…
Have a look at the Troubleshooting guide for high battery drain. Following the tips carefully usually fixes problems appearing after firmware updates.
currently on the beta software. The watch has been performing sluggishly so I did a hard reset. This made the system speed back up but last night I saw a battery drop of 50% overnight. Aside from the most recent issue with the battery drop, I’ve been…
With these two news updates, my battery drains 100% to 0% in 3 days without using music or gps...
Please, fix it!
After the 12.13 update, instinct's battery started draining within 3 days, even with the economy settings.
I installed the 12.15 update, but it didn't solve it. I deleted the Apps folder, performed the hard reset to version 11.18 and it didn't work either…
I have a Fenix 6 Pro that I bought in 2021 and I know has a failing battery. Normally I can charge it 2x per week and its fine. Yesterday I charged it to full, and this morning the screen was blank and when I re-started the watch it was down to 4%. I…
