I've been seeing significant battery drain on both my Epix's watches since updating to 14.31. Is anyone else seeing the same?
Huawei P30 pro, high power usage alerts ,battery draining.
No issues with previous version .
Epix gen 2
After the 19.34 more than 2% battery drain per hour.. Garmin epix pro.
Mine epix standard 47 battery draining issues started after installing 17.28. I downgraded but avail. Its definitely Garmin software they released causing the problem.
With software 17.10 on my Epix 2 Pro I am experiencing battery draining. My watch only run for one day before it needs to be recharged. It started when I updated it to 17.10.
Has Garmin responded about this issue?
Have you contacted Garmin Support?
The only hope is
…to contact Garmin Support and ensure they know of a potential problem.
Battery Drain still appears to be a problem on my Epix Gen 2. I've tried all of the resetting techniques found in the 17.xx forum.
Since I updated my epix pro to 14.68 my battery drains from a full charge (when battery life estimate says it'll last for 14 days) to dead in 4 days. This is without any activities and without changing any setting since changing it. Anyone else having…
But you ?
Nope. Been running 9.36 on both my tactix 7 Standard and epix Gen2 with no unusual battery drain.
